Hello,
Does the service checking is base on their order in the page? (I think it does, just to confirm)
long time i am looking for an option to move the services up and down, as from time to time we get URL pattern to added but they can't be at the end where new service are created they should come up in the list.
Regards,
Yohai
Good day. The services within the HTTP(S) farms are checked sequentially, so the order is important.
There is no option to move the service block in the community version, only in the enterprise. Apologies for the inconvenience; however, you can move the service block by editing the file directly from the command line. The configuration file for the farm is located at: /usr/local/skudonet/config/<farmname>_proxy.cfg
Thanks!
Hi Emilio,
Thanks for your answer.
Command line is a great alternative.
Regards,
Yohai
Thanks for the confirmation.
We will proceed to close this topic as the doubt has been managed.
Regards!
