401 Authorization r...
Notifications
Clear all
[Solved] 401 Authorization required via webui
2 Users
0 Reactions
(@alanmartin)
Member Admin
Topic starter   [#6]
Using the webui, when logging in with the correct user/pass I get a 401 error. Same credentials work via ssh.
2025-01-21T11:53:55.478508-05:00 svace01 zapi.cgi[521820]: (INFO) webgui :: Authorization required
2025-01-21T11:53:55.519370-05:00 svace01 zapi.cgi[521821]: (INFO) webgui :: STATUS: 401 REQUEST: GET /zapi/v4.0/zapi.cgi/system/version
2025-01-21T11:53:55.521114-05:00 svace01 zapi.cgi[521821]: (INFO) webgui :: Authorization required
2025-01-21T11:54:07.185577-05:00 svace01 zapi.cgi[521822]: (INFO) webgui :: Login successful for user: root
2025-01-21T11:54:07.192290-05:00 svace01 zapi.cgi[521822]: (INFO) webgui :: STATUS: 200 REQUEST: POST /zapi/v4.0/zapi.cgi/session
2025-01-21T11:54:07.362511-05:00 svace01 zapi.cgi[521824]: (INFO) webgui :: STATUS: 401 REQUEST: GET /zapi/v4.0/zapi.cgi/system/info
2025-01-21T11:54:07.367720-05:00 svace01 zapi.cgi[521824]: (INFO) webgui :: Authorization required
When using the invalid credentials I get the user/pass error as expected.
2025-01-21T11:55:09.685447-05:00 svace01 zapi.cgi[521830]: (ERROR) webgui :: Login to new session: The username and/or password are incorrect
Quote
emiliocm
(@emiliocm)
SKUDONET Engineer Moderator
Good day. First of all, we need to understand if the issue is related to some special characters not being properly managed by the HTTP encode/decode or if the problem is in the validation module. So, please can you do the following test and share the results with us?
For the affected user configure a simple password using ssh.
Later validate on the web GUI with this user and the simple password.
Please confirm if it works as expected or if the issue remains.
ReplyQuote
(@alanmartin)
Member Admin
Topic starter
This has been resolved.  It appears the file system became read-only even though items were still being written to /var/log/syslog.  A restart fixed it.
ReplyQuote
emiliocm
(@emiliocm)
It makes sense; thanks for the confirmation. Maybe the Hypervisor configured the Storage to be read-only due to an unexpected issue.
Thanks for reaching us and sharing with us this issue, a pleasure to help.
We will close this topic.
Regards!
ReplyQuote
Share:
