I don't know if I made a configuration mistake or not, but farmguardian UDP isn't working well.
I tried to copy check_udp_nc farmguardian by turning on the logs and tried to apply it to one of the udp farms.
Here are the logs that might help. I also tried the command on farmguardian check_udp_nc manually and it worked.
Thank You.
Hi Pahala,
There is a link missing.
Execute this command to fix the issue:
# ln -s /usr/bin/nc /usr/lib/nagios/plugins/nc
The fix will be included in the next release.
Regards!
Hi Pahala,
Regards!
Thank you, now it is working well.
