Download the SKUDONET Enterprise Edition – 30-day fully functional trial
Fill in the form to download the fully functional 30-day trial and evaluate SKUDONET in your own environment.
You’ll get full access to all load balancing, security, HA, and monitoring features — and you can request assistance from the SKUDONET technical team at any point during the evaluation.
Customizable security rules – WAF protection against SQLi, XSS, DDoS, and IPDS system.
Web GUI management – Configure and monitor without using the command line.
Engineer assistance – Optional support or personalized demo during evaluation.
High-capacity load balancing and HA – Multi-protocol support, clustering, and failover.
Encrypted traffic inspection – TLS/SSL offloading with certificate visibility.
Enterprise Edition Evaluation Request
Click here for more information “We manage the information you provide with the sole aim of assisting with your requests or queries in regards to our products or services; applying the computer and security procedures to ensure its protection. Your data can be rectified or removed upon request but won’t be offered to any third parties, unless we are legally required to do so.” Responsible: SKUDONET SL - info@foroskudonet.alanmartin.dev
WATCH HOW IT WORKS
See how SKUDONET is deployed and activated
Watch a quick walkthrough that shows how SKUDONET is deployed and configured before first use — including the steps you’ll follow during your evaluation.
Key Metrics & Insights
475,000+ RPS
L4 throughput with only 27.7% CPU usage
17M+ users/second
Theoretical capacity under L4xNAT
100,000+ RPS (HTTP)
Stable L7 processing even at maximum load
93,000+ RPS (HTTPS)
High-performance SSL/TLS offloading
Frequently Asked Questions about the 30-day version
Is the 30-day version fully functional?
Yes — it includes all Enterprise Edition features without limitations.
Which environments can I deploy it on?
Bare metal, virtual machines, cloud instances, or SkudoCloud SaaS.
Does the evaluation include security features?
Yes — full WAF, IPDS, TLS/SSL inspection, DoS protection, and real-time monitoring.
Do I need a credit card?
No — only a corporate email is required.
Can you help me with the installation?
Yes — our engineering team is available if you need guidance during your evaluation. Simply contact us and we’ll assist you.
Can I extend the evaluation?
Extensions are available in some cases. Contact us if needed.
Get started
Ready to validate SKUDONET in your environment?
Download the 30-day demo and verify load balancing, HA, and security features directly in your setup.
Start 30-Day Evaluation
Do you have more questions?
You can contact our team who will answer any questions you may have.
Contact us
